shopwit Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Honeygrid 25 degree Profoto magnum grid vs. 10 degree grid | |
for Honeygrids 25deg. here is various E-Series and other series light products available on line,like HoneyGrids E10 25deg. Grid for Elinchrom 10-1/4" Reflector, White,HoneyGrids SaberStrip 15deg. Grid, Black,HoneyGrids Speedotron 7" 3deg. Honeycomb Grid,HoneyGrids 12x12" 20Deg. Light Diffusion Polycarbonate Grid Material, White etc.find at reasonable prices. and for other side 10 deg grid is "The Impact 7" Grid (10 Degree) helps you control your light more precisely: this honeycomb grid, which will fit any standard 7" grid reflector (other than Broncolor or Profoto), gives you a very narrow 10° beam of light, perfect for an accent light or spot. A tension spring can stretch or arch to fit the reflector."
