msalvetti Offline Upload & Sell: On
p.1 #9 · p.1 #9 · How to check the shutter count, on a Canon 7D? | |
Yes, the file numbering resets after 9999. The first image shot will be IMG_0001, and the 10,000th image shot will be IMG_0001. The camera will also pick up file numbering off the memory card, even if that memory card was used in a different camera. So for example if your last file name from your camera was IMG_2000, and you insert a card that was used in a different body who's last image was IMG_4000, the next image in your camera will be IMG_4001. The camera will pick up the numbering from the last image number it took, or the last image number on the card, whichever is higher.
Formatting a card in your camera does not wipe out its file numbering memory. You have to format the card in a computer to do that.
As for shutter count apps, I've found Focal is accurate with my 1DIV (matched the number from Canon service) and my old 7D.
Mark
