OntheRez Offline Upload & Sell: On
irifan,
You've stumbled onto one of the truly infuriating and mystifying disjuncts between capturing an image and printing it. As others have noted, the "standard" crops in both Lr and Ps are ratios not measurements, thus a 4x5 crop could be printed as 2"x2.5" or 20"x 25". The ratio doesn't determine the size. You determine that in the print module of Lr.
Now for the crazy part. Somewhere in the dim recesses of photographic history someone decided that the "proper" size of a photo was 8X10. Go into any Michaels, Walmart, Target, any mass seller of pre-made frames and mats and you'll notice a couple of zillion options for the 8X10 and far fewer for other formats. Maybe it was the school picture guys? Any dinosaur older than me have any knowledge of what those guys were shooting? I believe I remember that one common "medium format" was 4x5 or 4x6 (as in size of the film frame).
Along comes the SLR and "35mm" film. The actual size of the image window was about 24mm x 35mm thus from that we now have "full frame cameras" that incorporate that default ratio. Just how/why that became so was probably partly driven by marketing droids and partly by the fact that the SLR was the camera DSLRs were trying to replace.
So if you are shooting with a "full frame camera" (I don't think the d7000 is, maybe 1.5x1?), your raw file will have a 2x3 format. If we want to keep all the pix and put it into 8"x10", it just doesn't work. Something has to be cut off. It is maddening as my clients mostly want 8x10 (they've been trained to think this by the market) and I have to figure out how to get as much in as possible. I will admit that for portraits and say family groupings the 8x10 tends to work. For most other things? Not so much.
About all I can suggest is to get a box of relatively cheap photo paper (Costco, Walmart, etc.) and start experimenting. While there is a "zoom to fill" option in the Lr print module this often produces distorted images so isn't that useful.
So good luck, have fun, and try not to toss your printer out the window when you don't get what you expect
Robert
