Shasoc Offline Upload & Sell: On
Viewfinder illumination
Information on the focus screen can be set to illuminate briefly in certain conditions for better viewing in low light. This is actually set in the EOS 7D Mark II’s AF menu: 5th AF menu screen > VF display illumination:
Auto
Red illumination of AF points, Grid Lines, or any other viewfinder info on the focus screen when the camera detects low-light conditions (there’s no way to change the factory-set cut-off point for illuminating vs. not illuminating).
Enable (ON)
Red illumination is always active, regardless of ambient light level. Illumination is limited to when AF is actually being activated; it does not simply constantly illuminate.
No illumination of viewfinder info that’s over the focus screen, regardless of ambient light level.
An important aspect of viewfinder illumination in the EOS 7D Mark II is that if active, it’ll appear differently in One-Shot AF vs. AI Servo AF. In One-Shot AF, when you press whichever button activates AF, it’ll flash briefly upon completion of AF, so you can visually confirm which point(s) are active and where they fall in the scene. In AI Servo AF, it behaves like the EOS-1D X with version 2.0 or higher firmware installed — during continuous AI Servo focus-tracking, the red illumination flashes on every second or so, briefly, then goes off. Again, there’s no way to have it simply illuminate constantly, regardless of the light level.
What about if you’re using Manual focus? If you’ve got the lens set to MF and press actively on whichever button would have been your AF activation button, you’ll get focus confirmation in the viewfinder when you do achieve sharp focus and the red illumination will flash briefly (as in One-Shot AF) when that happens. But again, it won’t illuminate continuously, even if the menu for illumination is set to ON.a
