mrchile Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · Triple Falls, Ar.- The crop is difficult for me! | |
First, crop is probably the wrong term to use.
Cropping is what you do to an image after you take it, to eliminate distracting areas to achieve a stronger composition.
Framing is what you do with the camera as you take the picture to achieve the desired composition.
If you can't get everything you want in a single frame, consider taking several frames that would include all the parts you want and combine them into one image with panoramic stitching software.
I like the way you did this with one frame, but I see what you mean about having more at the top.
A couple of stacked frames would help you get that.
