Vcize Offline Upload & Sell: Off
I originally posted this in the critiques section but it was suggested that I add it here since you guys will have better insight with regards to these two cameras specifically.
I have a Nikon D750 and D800e. I was attempting to run an ISO test on the two, but I can't put my finger on why the two came out with such a different color balance.
Photo is viewable here
Here was my method:
Put D750 with 14mm rokinon on tripod, focus. Shoot manual, f2.8, 30sec, ISO12800. Then I removed the D750 and replaced it with the D800e, attached the same lens to it without moving the focus, and also set it to f2.8, 30sec, ISO12800.
Now, I did accidentally leave the white balance on auto. However, since these were both shot in RAW I was able to adjust that in Lightroom. Both white balances were set to a temp of 4150 and tint of +14 in Lightroom.
Why are the colors so different? The D800e (right side) has a much stronger yellow/orange tint to it than the D750 (again, same lens) almost as if the white balance were warmer, but the white balance has been set to the same now. Is it normal to see such a vast difference in colors between two similar cameras?
