elliotkramer Offline Upload & Sell: Off
Having done hundreds of headshots professionally, I believe the second one is the best, but as headshots go, these don't quite hit the mark, unless you are using the word "headshot" as a generic term. The term headshot has a specific meaning to photographers. I assume you are trying to produce the kind of headshot that an actor would use to find work. Those have to really make an impression. The shots you posted don't stand out. The lighting is pretty flat. There is a lack of intensity. The angle seems a little low. And, they are unfinished in terms of the kind of post processing usually done. They also seem a bit hot and a bit warm. As with many things, it is hard to put it into words, but when you see a great headshot, you know it. I'm just not feeling it here. These are merely competently done images.
