Gene_C Offline Upload & Sell: Off
It's not an idea, it's a global adjustment that effects all lenses. Here is a post from someone else that used the adjustment to his advantage. I am doing the same thing on my D750, all of my lenses are meticulously adjusted spot on.
"I spent days trying to fine tune all my lenses (all about -20), with poor results, not good for all apertures.
Finally I tried the DEFAULT setting, removing all saved values for each lens, putting just -8 as default.
All lenses now give perfect focusing, at all apertures and focal length, tested with Lensalign!
Maybe this is not the solution for all cases, but I suggest to try! Wink "
Vincenzo
Note that after a default setting is made, each lens is still adjustable using the normal MF adjustments. It will now have the default adjustment added to it.
