Monito Offline Upload & Sell: Off
I would not worry about it. Even if you get diffraction at 100% view there is going to be a lot more detail on the 5DSR file compared to the 5D3 file.
+1
But Jeff, you don't say how large you really need the images. That is the key factor.
If you make a 19 x 13 inch print from both cameras, you will see the same amount of diffraction effects at the same aperture, for example f/13 or f/16. In fact, you will generally find it difficult to tell the two apart since you have lots of controlled light in making your photographs.
If you wish to blow up the images to (say) 30 x 20 inches, then the 5DS file will be considerably more detailed. But that detail will be more prone to diffraction. At f/13, some of that detail will be softened slightly.
When you say 200%, is that for you or for customers? Are you printing or only showing images on tablets / monitors? How big are the dimensions you show them at?
