Archive 2015 · FM Plugins and PS CS6 64 Bit
StGeorg
p.1 #1 · p.1 #1 · FM Plugins and PS CS6 64 Bit
Hello!
After installing Velvia Vision v1.5 (PC) I was not able to find
the plugin in Photoshop - I use PS CS6 64 Bit.
Later I learned from this forum, that the plugin works with
Photoshop 32-bit only, although there is no hint to this fact
at < ;https://www.fredmiranda.com/shopping/vv>;.
Is this true, that I can not use the plugin or is the a way I can
use it with PS CS6 64 Bit?
Thanks in advance!
Jun 26, 2015 at 05:32 AM
James_N
p.1 #2 · p.1 #2 · FM Plugins and PS CS6 64 Bit
https://www.fredmiranda.com/forum/topic/1187466
Jun 26, 2015 at 07:18 AM
StGeorg
p.1 #3 · p.1 #3 · FM Plugins and PS CS6 64 Bit
It is a little bit confusing:
From the thread you mentioned: "Redesigned to work with CS3, CS4 and CS5"
The actual description says: "The PC versions do not work with CS5" and
"Redesigned to work with CS3 and Windows Vista"
If I understand correctly, VV runs under Win7 + PS CS6 in 32 bit mode. I have
Win7 + PS CS6 but in 64 bit mode only. No chance to use VV?
My file paths are:
C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\FM Plugins\Velvia Vision.8li
If it really does not work:
1. What about the other FM plugins? Would I face the same problems?
2. Is it possible to get back the money for VV as the restriction is not mentioned
and the was no chance for testing before buying?
StGeorg
Jun 26, 2015 at 08:04 AM
