atwl77 Offline Upload & Sell: Off
p.1 #8 · p.1 #8 · Problem with EPSON 3880 print colors not rendering correctly | |
mendo wrote:
Looks like the filters are not working. I originally worked up this file with NIK filters and recently upgraded my OS to Yosemite. The areas in the photo that are printing incorrectly are where the NIK filters are. There must be some incompatibility. Has anyone else had this problem?
I don't understand... are your filters directly interfacing with the print interface?
Or what I think you are saying is that your filters are utilising certain colours that come out wrong in the print? In that case, I suspect it would be a colour space conflict (perhaps even double-profiling) then?
If that is truly the case, make sure you know what colour space your image is in (aRGB or sRGB, probably). Then instead of letting the printer manage colours, try turning that off and let Photoshop manage colours instead. Also ensure that you use the correct ICC profile for the paper in Photoshop's print dialog. See if that is any better?
