weezintrumpete Offline Upload & Sell: On
p.1 #8 · p.1 #8 · What's a 50/1.4 alternative to the Sony RX1? | |
Steve Spencer wrote:
Yeah, I think you would want the A7 II with the Sony/Zeiss 55 f/1.8. It will be noticeably bigger, but way smaller than your 6D Sigma 50 f/1.4 kit and you get IBIS too. If you want a true 50, then try the Zeiss Loxia 50 f/2 with the A7 II, you might like the rendering better and it is a phenomenal lens. Yeah, you have to manual focus, but I doubt that would both you too much. The 50 f/2 can have a bit busy bokeh in some situations, but just the way 50mm lenses typically do.
I'd really want something faster than f/2, so the Sony might be the only option in that case, not the Loxia.
AmbientMike wrote:
I wish they'd make more 50/1.4's, maybe even if they just reworked old designs (would like an af version of OM 50/1.4 for m4/3.)
Will an old Maxxum 1.4 work somehow? I guess that is only for dslr and would require an adapter?
Yeah, I wished they did that too!
mawz wrote:
Fuji XA-1 with the 35/1.4 would be my suggestion. A little less resolution and a smaller sensor, but both camera and lens are gems and the package will cost less than most 50/1.4's.
DR on the 16MP APS-C sensor is a little behind the 24MP FF sensor, but still notably better than any Canon sensor. No X-Trans issues either as it's Bayer.
Flip side would be the A6000 with the ZA FE 35/1.4, but that's seriously nose-heavy and twice the cost of the Fuji setup.
Interesting suggestion, but I'm hooked on full-frame now. Can't go back to crop
Jorge Torralba wrote:
If your going as bnig as the 35mm 1.4 ZA, try the 50mm 1.4 ZA with the adapter. It is superb and smaller than the 35mm 1.4
http://jorgetorralba.com/2014/08/06/zeiss-55mm-1-8-fe-or-50mm-1-4-za-for-the-a7/
Hmm, interesting. It'd still be a pretty big setup with the required adapter, yes?
freaklikeme wrote:
Patrick, you should check out a7II and ZM Sonnar 50/1.5 samples. It's not the sharpest fast fifty, but it is, in my opinion, the most fun to shoot.
Now THAT's an interesting suggestion. I've always been interested by the C-Sonnar...images I've seen seem lovely. Downsides are: CA, long close focus distance, not AF?
arize84 wrote:
This is one of the best 50mm out there. It has amazing micro contrast and some of the most beautiful bokeh I have ever seen on any lens.
Yeah, I think I'm going to have to check that out.
Doesn't a ZM 50 1.4 planar exist? Or is going to exist at some point?
