ben egbert Offline Upload & Sell: Off
p.1 #15 · p.1 #15 · Xrite color checker passport fails to make profile. 5DS-R | |
Ok, it worked once, now it won't. If I select lossy compression, it says not a valid DNG when I try to load it into Passport.
The one time it worked with full uncompressed DNG, it was not able to find the the color checker but did when I selected the corners. But now it is back to the out of memory issue.
The preferences are lossy compression, preserve file size, or change file size or turn lossy off. It appears that lossy with preserve pixel count makes a small enough file, but it does not look like a valid file to Passport. With lossy turned off, it is too large.
