ontime Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · Travel Tripod for Non Serious Use (Sirui T-025X) | |
The Sirui T-025X is a very small, compact travel tripod. I believe it will be sufficient for your mirrorless system, however, if you're tall you might have some issues with its height. Also, you can't fold the tripod legs up over the ballhead unless the center column is attached, and the center column does not collapse down into the tripod. I found this to be an annoying combination of design choices.
I purchased one a few months ago and returned it because I felt it was a bit too small for my 6D and too short for me to use regularly (I'm 6'2"). I do believe it was well built and sturdy, just wasn't for me. I ended up going with a MeFoto Roadtrip Carbon, which I recommend. They also make a couple smaller MeFoto variants, the DayTrip and the BackPacker. http://www.mefoto.com/products/help-me-choose.aspx
Here are a couple comparison shots I took between the T-025X, the MeFoto Roadtrip Carbon (the tripod I ended up keeping) and my old C-157-M8:
Tripods by Michael Toyama, on Flickr
