gyoung143 Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · Am I chasing a Unicorn? Affordable 2.8 TLR | |
I don't know of another tlr with a 2.8 lens. I used a Mamiya c330 for quite a while and was happy with the 2.8/80. Of the wideangles the 55mm is quite a lot better than the 65mm but you probably will need to get the lens set up for your particular body, so that the focus is right as register is more critical.
With the Rolleis, the 3.5s with the Planar are generally reckoned to be better than the 2.8 versions, and I found it so, not enough room for a decent size front element so its a compromise compared to the 2.8/80 Planar for the Hasselblad.
With Yashicas, go for the Yashinon 4 element lens which is much beter than the 3 element. We had about 20 of these for student use and they were very variable even when new, some good, some poor.
You will have fun seeing the world flipped left to right, it takes a bit of getting used to!
Gerry
