dhphoto Offline Upload & Sell: Off
Bernie wrote:
Not sure if you can export a psd file from Lightroom. If not, export as tiff. Do your final edits in PS, then do a file / save for web with your 250k limit.
Depending on your final edits and what you actually do can significantly affect the jpeg size. Try applying some grain and see what hapens....
Yes, much better idea than messing around with tiny 250k files.
The reason you have the slider is because you can adust the compression of the jpeg file, the bigger the file the better the quality.
Export from LR as a normal sized file then use the PS save for web as Bernie suggests, you will get much better IQ that way
