Shutterbug2006 Offline Upload & Sell: Off
Check this out. http://bit.ly/16pPf1t
Canon EF/FD 5200mm F14 Prime Lens. The world's largest dedicated SLR Super Telephoto lens.
Extremely rare. Made in Japan.
From a Canon Flyer:
"This is the only ultra-telephoto lens in the world capable of taking photographs of objects 18 to 32 miles away (30km to 52kms away). Having a focal length of 5200mm, Canon Mirror Lens 5200mm can obtain one hundred times as large an object image as that of a 50mm lens."
"For focusing this mounted or fixed lens on an extremely distant object, two aiming telescopes are set on the side of the lens barrel, and the entire lens is placed on a rigid stand which rotates smoothly. Minimizing the overall length had been a big problem in designing this lens. However, the Catadioptric system that is applied to the other two Canon mirror lenses (Canon 800mm f3.8 & 2000mm f11) has succeeded in reducing it down to one third of the nominal focal length. In general focal length and optical aberration increase with each other, however, our long and persistent research and development have succeeded in solving this problem. Canon mirror lens 5200mm composed of spherical main and secondary mirrors and a correction lens would assure you of clear images."
