AnnJS Offline Upload & Sell: Off
I merely relayed the information which Eric Chan (ACR Engineer) posted on the Adobe Forums:
https://forums.adobe.com/message/7470607#7470607
[Quote]
GPU performance in Lr CC will depend a lot on the control that you are editing, as well as what other settings (image adjustments) you have enabled on the particular image. At present, the most acceleration will happen when editing non-detail, global controls. For example, Basic, Tone Curve, HSL, Split Tone, Lens Correction, Post-Crop Vignette, etc. Many gradient and radial filter operations are also greatly accelerated.
Some other editing operations such as local brush adjustments and the spot tool do not currently take advantage of GPU acceleration.
If you heavily use these tools, then you may find that their performance (with the GPU feature checked) is on par with Lr 5 performance, or possibly slower due to additional overhead when using the GPU path.
[/Quote]
