rhorta Offline Upload & Sell: Off
My "old" 24-105 had developed an IS issue, where at 24mm the image would jump about instead of correcting motion in a fluid way - as it does through the rest of the range and like all my other IS lenses by Canon - and making a coffee grinder sound instead of the more normal purring.
So I sent it to CPS NL and it came back from repair - replacement of AF and diafragma components - but no improvement. Still very jittery at 24mm especially when touching the zoom ring.
Ok, return label and resent.
Today it came back - technic replaced (cryptic...) - and it shows some improvement.
The IS has become less jittery at 24mm and is less sensitive to zoom changes, but at 24mm its IS still jumps about more than any other IS lens I own.
Now before I go apesxxt, I'd like to ask those who have experience with the 24-105L if they have experienced similar issues and if it is actual normal 24-105 behavior - which I cannot believe although I haven't used this lens a lot, especially not on the wide end, I just cannot remember it ever jumped about until I found out a couple of weeks ago and saw it as abnormal behavior.
All help appreciated.
