e6filmuser Offline Upload & Sell: Off
I occasionally find adult carabid (ground) beetles under stones, logs or bark. Most are nocturnal and they flee when I expose them to daylight. This one was an exception. It not only stayed still for one session, which I then had to repeat because of an incorrect camera setting, but it stayed still a second time, having moved to a new position when the chunk of bark was in the position in which I originally found it.
Lighting a very shiny beetle is always problematic, whether by daylight or flash. A shiny black beetle seems even more difficult. I tried changing the angles for which my twin flashes were aimed, with limited improvement.
This beetle was around 20mm long. It is one of the genus known as Pterostichus or Feronia.
EM-1, 21mm extension, reversed Schneider HM 40mm at f16,twin TTL RC flash, one fre-standing, hand-held.
The images have been cropped slightly. The blur in the last one is the left antenna.
Harold
© Harold Gough 2015
© Harold Gough 2015
© Harold Gough 2015
© Harold Gough 2015
© Harold Gough 2015
