Thanks all. Larry, I was using the Harbor Digital thingy on a SB900. Never knew that you cannot use SB900 in a speed burst as it locks up every 10-15 shots. Apparently it is by design as per Nikon Support with whom I talked with. She asked to buy a SB910 or a SB700 if I did not want the feature
Shreeni, could it be the flash recycling time that is the issue. I have had this happen when using the SB900 and SB910 off camera using the pop-up flash as the commander.
My SB900 stops working with a temperature icon on the back once I fire a series and won't work till about 10-15 mins. Apparently it is some safety feature built-in to the SB900's. At least that was what I was told by support.
I had the SB on the hotshoe.
Mar 21, 2015 at 10:43 PM
Jonathan Huynh Offline Upload & Sell: Off
