oldrattler Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Don't Be Afraid of What's On the Other Side | |
AuntiPode wrote:
I suspect a longer tonal range might be better. The subject is quite gritty so a touch less gritty in the processing might also be better. I'm good with the square format, but if you'd have taken it from a little to the left, the door and message would have been less centered which would have been a plus, I suspect.
To answer directly, yes the image, as processed, is too busy. As Karen said, rule of thirds, tonal range & contrast can do a lot.
