DavidBM Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · variable ND filter that's clear when not rotated? | |
No Kit no such thing. They work by effectively stacking a couple of polarisers on top of each other to variably cancel each other out (ie the first polarizer lets in only light Polarized in one direction, then the second polarizer works in letting through to different degrees only light polarized in another direction.
But polarizsers at any setting lose some light, usually more than a stop, so it's impreessive that these things can get down to two stops min.
Don't know which one you have but the cheap ones are nasty and the expensive ones really expensive. there have been some grat deals on Amazon for the Marumi DHG which was about the best value decent one, reduced from a couple of hundred to sixty bucks (I think a lot of people are put off them by the crazy aberrations they generate on wide angle lenses if you turn them up too high, but if you are careful they are about as good as decent plain NDs)
