Archive 2015 · Laser auto focus
Doug Maclean
p.1 #1 · p.1 #1 · Laser auto focus
Lg is putting in a laser focus into one its smart phones.Works in conjunction with phase contrast,phase detect.It is allot faster as it does not make the back and forth corrections to get the auto focus dialed in.How long before Nikon and Canon come out with it.You could get auto focus in a room we perceive as pitch black.Wedding photographer heaven. Doug M
Edited on Feb 10, 2015 at 07:25 PM · View previous versions
Feb 10, 2015 at 07:22 PM
ThomasCantwell
p.1 #2 · p.1 #2 · Laser auto focus
Sounds great, except the part where you blind your subject...
Feb 10, 2015 at 07:24 PM
Doug Maclean
p.1 #3 · p.1 #3 · Laser auto focus
It is just a laser pulse.not a beam.Doug M
Doug Maclean
p.1 #4 · p.1 #4 · Laser auto focus
I use a bosch laser measure for work and it is + - within 1/64".Makes sense to me for certain situations. Doug M
Feb 10, 2015 at 07:29 PM
johnctharp
p.1 #5 · p.1 #5 · Laser auto focus
It doesn't make a lot of sense for system cameras, as in order to make sure that the 'AF laser' clears lenses, it'd have to be situated off-axis, and it'd still have the calibration issue that phase-detection has between what a particular lens is calibrated to at a particular known distance.
Might work for point-and-shoot (and other fixed-lens) cameras, though!
Feb 10, 2015 at 07:51 PM
Doug Maclean
p.1 #6 · p.1 #6 · Laser auto focus
yeah that makes sense.A reason it is in a point and shoot now I guess.But could see how they could eventually work around that.Doug M
Feb 10, 2015 at 08:11 PM
Jason_Brook
p.1 #7 · p.1 #7 · Laser auto focus
If it's using a laser, I'd bet it'd be a range finder laser. Camera knows distance to subject from laser and focuses lens to that distance.
Feb 10, 2015 at 08:28 PM
Doug Maclean
p.1 #8 · p.1 #8 · Laser auto focus
what I was thinking was a through the lens where the laser would bounce off the mirror and calculate from there.Doug M
Feb 10, 2015 at 09:36 PM
snapsy
p.1 #9 · p.1 #9 · Laser auto focus
Hope the lasers from two separate phones don't cross otherwise the world will end.
Feb 10, 2015 at 09:38 PM
Doug Maclean
p.1 #10 · p.1 #10 · Laser auto focus
kaboom!!
Feb 10, 2015 at 09:53 PM
p.1 #11 · p.1 #11 · Laser auto focus
Just imagine having to remove the bright red dot from your subject's eye lashes. Would the red eye tool work for this?
JK
What we have now works very well though there is always room for improvement
Feb 10, 2015 at 10:23 PM
Joseph.
p.1 #12 · p.1 #12 · Laser auto focus
Just make sure you point it towards the Canons
Lasers Take Down a $20,000 Camera in Less Than One Second
Feb 11, 2015 at 03:15 AM
mawz
p.1 #13 · p.1 #13 · Laser auto focus
Laser AF is just one form of active AF. It shows up in P&S's every decade or so because it nets you rather fast and accurate AF on the cheap and doing AF on P&S's before the days of fast CDAF was always difficult.
Feb 11, 2015 at 08:11 AM
Mark_L
p.1 #14 · p.1 #14 · Laser auto focus
All sorts has been in older cameras before but it never seems to stick eg. Contax T2 had active infrared focusing. I wonder how well laser range finders work at infinity distances?
Feb 11, 2015 at 12:51 PM
binary visions
p.1 #15 · p.1 #15 · Laser auto focus
The Sony DSC-F717 projected a laser pattern for autofocus assist and it was actually pretty excellent for taking flash-assisted pictures in low light. It allowed you to focus in dark situations without blinding your subjects (or calling a ton of attention to yourself) by using an AF assist light.
That was an awesome camera for its time.
Feb 11, 2015 at 03:35 PM
hjanssen
p.1 #16 · p.1 #16 · Laser auto focus
How can you set the laser to 51 spots?
Feb 11, 2015 at 04:42 PM
Doug Maclean
p.1 #17 · p.1 #17 · Laser auto focus
I think an F22can lock on 51 targets at one time.Just costs a bit more though
Feb 12, 2015 at 06:51 PM
Squinty
p.1 #18 · p.1 #18 · Laser auto focus
Yeah, I'm sure vicars will love it.
Feb 12, 2015 at 07:04 PM
Fishinfool
p.1 #19 · p.1 #19 · Laser auto focus
I am sure a laser based focusing system would work well in a cell phone camera system. But, lasers do have issues. A lasers range can vary, based upon such variables as sunlight, atmospheric conditions, target reflectivity. The most powerful lasers now in use, as allowed by law for civilian use, tend to be used on laser range finders often used by hunters. Some models advertise a 1500 yard range, but that is under optimal conditions. Depending on the target, 3 or 400 yards is all they will do reliably.
Lasers used for ranging (or focusing a lens) do not project a visible, solid red dot.
Larry
Feb 13, 2015 at 01:01 AM
phototronix
[X]
p.1 #20 · p.1 #20 · Laser auto focus
thats pretty dam awesome, for every camera guy would a good camera in a phone is important .I don't really care how fast the autofocus is, but if this really helps to get the focus right in very minimal lighting conditions, it's a good feature indeed.
Feb 13, 2015 at 05:49 AM
