CanadaMark Online Upload & Sell: Off
I think a used D800/E is a no-brainier in your situation. That way, if you need to use it for your usual landscapes, you aren't giving up resolution or much in the way of DR. Handling & controls are also very similar, and accessories are the same.
While the D610 is an outstanding body, it has significantly less resolution and different controls and ergonomics to get used to. Also for cable releases you would need to move from 10-pin to DC2, which is an unnecessary investment.
Personally, if I had a backup body with "lesser" image quality (eg. a M43, or APS-C DSLR) I get the urge to go back and try get the same picture with my "main" camera, especially if I was going to make a big print. With a D800/E you won't have that issue either if you need to reach for your backup.
