Beni Offline Upload & Sell: Off
We have been using the 120mm f4 Macro, AF version, for two years. It is not as sharp/contrasty as the 80mm Schneider (both used on 40 megapixel digital back) however it is heads and shoulders above the Nikkor 105mm Macro at the edges of the frame which according to Photodo testing is better at the corners and edges than the Zeiss equivalent. Keep in mind that the digital back we have is not FF 645 so it's not using the absolute edges of the lenses whereas the D800e is going right to the edge of that 105mm. Using the mamiya, which is a flat field lens, on a DSLR will mean a heavy crop of the image circle which should keep the corners significantly better, if the overall resolution can keep up with that pixel pitch.
