jdc562 Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · Using long lens with BlackRapid Strap and monopod. | |
I do it when hiking with long lenses and tripods. However, note that there are two kinds of strap connections to your camera/lens. Both kinds connect to your threaded mount, but one kind monopolizes the mount and requires you to disconnect the strap to connect to your monopod/tripod. The other uses a connection setup with a built-in monopod/tripod plate (e.g., Arca Swiss style plate), which allows you to connect to your monopod/tripod without screwing/unscrewing anything. I use the plate type because (1) it is much more quick and convenient, and (2) safer because your camera/lens combo is always on the strap--and there is less chance of dropping your camera or lens while screwing/unscrewing connections. If you choose this type, be sure to get a strong one that attaches to the camera/lens base mount and not to the strap eyes.
Imagemaster's advice adds further safety.
