Eyeball Offline Upload & Sell: Off
No, you need to use the mini-dongle in a USB port. It will not work with Bluetooth or WiFi.
If you need more USB connections for your iMac or Surface, a USB hub might work for you. It's another piece of equipment to lug around but they make them pretty small for portable use. There might be a possibility that the mini-dongle would not work on a hub but I would say there is a high probability that it would work.
