Weez Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Location of D750 Multi-Selector Dial Awkward? | |
It does seem like it would be much better if it was placed higher and to the left a bit, but there's obviously no room to do this with its design. I've stopped trying to work it with the end of my thumb and now I just use the part which naturally falls over it (the pad of my thumb near the joint).
It did feel a bit weird at first, and I kept hitting the ok button by mistake, but it's getting smoother and actually requires very little movement back/forth and up/down.
I can see where if you try to use the tip of your thumb for hours on end, it might cause cramping.
