Archive 2014 · Canon 70-200/2.8 IS mkI or non IS?
SunBlack
p.1 #1 · p.1 #1 · Canon 70-200/2.8 IS mkI or non IS?
On FF camera, on corners, is better version IS mkI or non IS? FL: about 80mm, about 180mm @ f2.8 to f4 ......
Dec 07, 2014 at 11:41 AM
gdanmitchell
p.1 #2 · p.1 #2 · Canon 70-200/2.8 IS mkI or non IS?
You are worrying about the wrong thing here if your deciding factor is sharpness. Both of these lenses produce outstanding image quality, and you are unlikely to see any difference in your photographs. Perhaps if you conduct controlled, clinical tests and stare at 100% crops on the screen side-by-side you may be able to convince yourself that you see a difference somehow, but it will be completely irrelevant.
The real question is whether you need IS or not.
Dec 07, 2014 at 12:02 PM
15Bit
p.1 #3 · p.1 #3 · Canon 70-200/2.8 IS mkI or non IS?
I agree with Dan. I have the non IS. It's been my primary lens since i got it and i'm still in awe of the photos i can take with it. General opinion seems to that the non-IS performs better than the IS, but once the shutter speed drops below 1/200 i would happily trade some of the inherent sharpness for some IS-assisted sharpness.
Dec 07, 2014 at 03:24 PM
SunBlack
p.1 #4 · p.1 #4 · Canon 70-200/2.8 IS mkI or non IS?
I'd use the lens for astrophotography so the IS is irrilevant
Dec 07, 2014 at 05:05 PM
Jeff Donald
p.1 #5 · p.1 #5 · Canon 70-200/2.8 IS mkI or non IS?
The comparisons at The Digital Picture may be what you are looking for. His results mirror my real world experience with both lenses.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=103&Camera=453&Sample=0&FLI=4&API=0&LensComp=242&CameraComp=453&SampleComp=0&FLIComp=4&APIComp=0
Dec 07, 2014 at 05:08 PM
SunBlack
p.1 #6 · p.1 #6 · Canon 70-200/2.8 IS mkI or non IS?
According the The Digital Picture comparisons, IS is better than non IS at corners....at 200mm .
At 85mm non IS is better instead........
Dec 07, 2014 at 05:16 PM
p.1 #7 · p.1 #7 · Canon 70-200/2.8 IS mkI or non IS?
Then, I think you should get something else.
I've owned all of the EF 70- and 80-200mm L lenses at f/2.8 and f/4 (IS and not), except for the 70-200/2.8L (non-IS) that you're asking about. That's why I didn't pipe up, until now.
They're all excellent lenses, but if you want to get the best IQ from centre to corner, especially for shots at 'infinity', then you might want to consider some "Alt" manual focus prime lenses, specifically;
at the shorter end:
Leica Elmarit R 90/2.8 E55
Carl Zeiss Sonnar T* 100/3.5
at the longer end:
Leica Apo-Telyt-R 180/3.4
Mamiya A 200/2.8 APO
Don't get me wrong. I have some dynamite EF autofocus lenses, but when I have a specialty application, I use special lenses.
Dec 07, 2014 at 05:36 PM
SunBlack
p.1 #8 · p.1 #8 · Canon 70-200/2.8 IS mkI or non IS?
I need a zoom, to razionalize my setup.....too much lenses i own at present.........
Dec 07, 2014 at 05:45 PM
p.1 #9 · p.1 #9 · Canon 70-200/2.8 IS mkI or non IS?
OK then. You know, that's crazy talk.
Dec 07, 2014 at 05:48 PM
skibum5
p.1 #10 · p.1 #10 · Canon 70-200/2.8 IS mkI or non IS?
I know that the non-IS has a good deal less longitudinal CA (purple fringing and such) which might make it nicer for astro??
The non-IS also has better micro-contrast at 200mm f/2.8.
OTOH the non-IS while crisp to corner on APS-C seems to drop off to the corner on FF. I never tested it, but I've heard the IS holds up better on FF corners even though it's not quite as crisp in the center region.
If you could get by with f/4, the f/4 IS combines the best of both worlds (as does the 2.8 IS II and even moreso, of course the price on that might be too much).
Dec 07, 2014 at 07:53 PM
skibum5
p.1 #11 · p.1 #11 · Canon 70-200/2.8 IS mkI or non IS?
Dec 07, 2014 at 07:54 PM
gdanmitchell
p.1 #12 · p.1 #12 · Canon 70-200/2.8 IS mkI or non IS?
Just to summarize a bit, it is my view that every 70-200mm lens that Canon has made recently is a great optical performer. That doesn't mean they are exactly identical, but it does mean that sharpness is likely the least important distinguishing characteristic among them. Way more important, it seems to me, are things like:
1. Cost
2. Weight/bulk
3. IS or not
4. f/4 or f/2.8
5. And, related to all of this, how these lenses fit in with other lenses you have.
Dec 07, 2014 at 09:40 PM
Paul Mo
p.1 #13 · p.1 #13 · Canon 70-200/2.8 IS mkI or non IS?
Lenses too many he has. Hmmpf, Jedi the lens does not make.
Dec 07, 2014 at 09:44 PM
Tom Dix
p.1 #14 · p.1 #14 · Canon 70-200/2.8 IS mkI or non IS?
Fwiw, I never liked the IS mk 1 beyond 165mm.
However, if you need IS, there is no substitute.
Dec 07, 2014 at 09:46 PM
rxgolf
p.1 #15 · p.1 #15 · Canon 70-200/2.8 IS mkI or non IS?
I have liked them all and not smart enough to distinguish pictures that came from one or the other. This is one of those times you can't go wrong. Find a deal and grab any one of them!
Greg
Dec 09, 2014 at 11:02 PM
popinvasion
p.1 #16 · p.1 #16 · Canon 70-200/2.8 IS mkI or non IS?
Just get a 200 2.8L, then see what you need.
Dec 10, 2014 at 01:50 AM
Tapeman
p.1 #17 · p.1 #17 · Canon 70-200/2.8 IS mkI or non IS?
When I went from the 70-200 non IS to the IS MK 1 I found the image quality to not be as good as the original lens. (not by a huge amount, but noticeable.)
The MK II is far superior and IMO worth the extra money.
Dec 10, 2014 at 09:57 AM
SunBlack
p.1 #18 · p.1 #18 · Canon 70-200/2.8 IS mkI or non IS?
MkII is over budget.
870$ is a nice deal for a second hand non IS? (keep in mind i live in Europe, prices are higher than US)
Dec 10, 2014 at 10:15 AM
gdanmitchell
p.1 #19 · p.1 #19 · Canon 70-200/2.8 IS mkI or non IS?
How is its performance in the 70-199mm range?
Dec 10, 2014 at 10:28 AM
gocolts
p.1 #20 · p.1 #20 · Canon 70-200/2.8 IS mkI or non IS?
For me, no matter how much I twisted that ring on the lens, it just took the picture in and out of focus as opposed to zooming....
Dec 10, 2014 at 01:10 PM
