NathanHamler Offline Upload & Sell: Off
p.1 #1 · p.1 #1 · Issues With LR5 Lens Correction as User Preset | |
Ok, so for some reason i can't figure out how to get my LR preset that applies my "camera calibration" and lens correction to work correctly....So, i have a preset set to apply on import, which changes my profile to "Camera Neutral", and then applies lens correction profiles. The problem is, when i CREATE the preset, it uses the profile for whatever the initial lens was that i used on the image i created the preset off of.....does that make sense?
So i open an image.
I check "enable profile corrections"
I select "nikon" from the drop down menu, and it automatically knows i'm shooting with an 18-35.
I select my Camera Neutral profile.
Then i create a user preset, i check the appropriate parameters.
So now i have a preset that will change my camera profile, and my lens correction profile. Except, now when i go to apply this to an image that was shot with, say, and 80-200, it still picks the 18-35 profile. I know there's got to be a way to get it to automatically recognize what lens it was shot with......all i have to do is pick the lens brand, and i KNOWS from the exif what the lens model was...? i'm lost....When i set this up on my other computer, i'm almost 100% positive that when i apply this preset on import, it applies the CORRECT PROFILE to images shot with different lenses...but on my laptop it's not working the same....
Thoughts?
