Archive 2014 · Sandpiper Assortment
p.1 #1 · p.1 #1 · Sandpiper Assortment
I visited Jones Beach today and the clouds got thicker and thicker leaving me with dark gray conditions. At least it was warm so it was a pleasant stroll on the beach.
The darker sandpipers with the hooked beak are dunlin, the lighter ones are sanderling.
-1
113014DSC_4863 by Morris0, on Flickr
D300 + 80-400 VR @ 400mm, ISO 400, 1/100, f5.6, fill flash (SB910 + Better Beamer)
-2
113014DSC_4869 by Morris0, on Flickr
-3
113014DSC_4901 by Morris0, on Flickr
-4
113014DSC_4915 by Morris0, on Flickr
D300 + 80-400 VR @ 400mm, ISO 400, 1/80, f5.6, fill flash (SB910 + Better Beamer)
-5
113014DSC_4972 by Morris0, on Flickr
-6
113014DSC_4980 by Morris0, on Flickr
-7
113014DSC_4983 by Morris0, on Flickr
-8
113014DSC_5027 by Morris0, on Flickr
D300 + 80-400 VR @ 400mm, ISO 400, 1/50, f5.6, fill flash (SB910 + Better Beamer)
Nov 30, 2014 at 09:27 PM
pdmilesjr
p.1 #2 · p.1 #2 · Sandpiper Assortment
They're nice, Morris, but I would have upped the ISO to 1000 and gone for a faster shutter speed.
Nov 30, 2014 at 09:50 PM
eyelaser
p.1 #3 · p.1 #3 · Sandpiper Assortment
Bad weather makes for good Morris....you do make the most out of the opportunity to be creative regardless of the conditions.
Eric
Nov 30, 2014 at 09:56 PM
canon.eos30d
p.1 #4 · p.1 #4 · Sandpiper Assortment
Very neat, Morris. I love how you play with slow shutter to create the motion blur with this fast little birds.
- Tam
Nov 30, 2014 at 10:36 PM
surfnron
p.1 #5 · p.1 #5 · Sandpiper Assortment
I like this Morris set Morris ~ Ron
Nov 30, 2014 at 11:06 PM
DonGut
p.1 #6 · p.1 #6 · Sandpiper Assortment
Interesting "look" to these with the flash eyes highlights but the blurred movement. Last two for me.
I might try to make more of a pano out of the last one and remove the white from the bottom totally and most from the top. That would accent that colour and the movement.
How you do that with a flash is beyond me!
Don
Dec 01, 2014 at 12:46 AM
kdacharya
p.1 #7 · p.1 #7 · Sandpiper Assortment
Hi morris, you are one brave dude...
1, 4 and 8 for me..
Dec 01, 2014 at 01:12 AM
kmunroe
p.1 #8 · p.1 #8 · Sandpiper Assortment
a nice lookin set Morris
Dec 01, 2014 at 04:20 AM
Lilki
p.1 #9 · p.1 #9 · Sandpiper Assortment
Nice series Morris. You have me thinking about trying out the Better Beamer. #8 makes for an interesting shot. Those li'l guys are bookin' it.
Dec 01, 2014 at 05:33 AM
KCollett
p.1 #10 · p.1 #10 · Sandpiper Assortment
Good stuff Morris.
Dec 01, 2014 at 09:24 AM
Shasoc
p.1 #11 · p.1 #11 · Sandpiper Assortment
Cool looking set, Morris.
Socrate
Dec 01, 2014 at 10:32 AM
p.1 #12 · p.1 #12 · Sandpiper Assortment
thank you Paul,
What you suggest will produce photos that look like very one elses so even the best are still ordinary. I looked at some of my published photos. Both of the ones that National Geographic picked up use motion blur and of the two that Popular Photography used, one had motion blur and the other was high key and a centered vertical composition. I do like to use pretty light for my blurs, it was not there.
Eric
Thank you Eric,
Bad weather is good for photography
- Tam
Thank you Tam,
I have a blast doing it.
Thank you Ron
Don
Thank you Don,
I like your idea of removing some of the white frame for the last image
1, 4 and 8 for me..
Thank you Kdacharya,
The first few times I showed this type of work I was concerned how people would react. Now I'm quite confident.
Thank you Kenny
Thank you Lilki,
The beamer is a good tool, it can take some getting used to as it changes the way some flash systems behave
KCollett wrote:
Good stuff Morris.
Thank you Ken
Socrate
Thank you Socrate
Dec 01, 2014 at 07:55 PM
kdacharya
p.1 #13 · p.1 #13 · Sandpiper Assortment
Morris, I was referring to you braving the elements.
your understanding of the light and use of the flash and the beamer is beyond compare..
Dec 01, 2014 at 11:41 PM
Lightsearcher
p.1 #14 · p.1 #14 · Sandpiper Assortment
The last one is beautiful, you early master the use of flash and low shutter speed.
Dec 01, 2014 at 11:49 PM
p.1 #15 · p.1 #15 · Sandpiper Assortment
Thank you for the clarification and complement Kdacharya
Thank you Marcelo,
Dec 02, 2014 at 08:12 AM
Michael Rucci
p.1 #16 · p.1 #16 · Sandpiper Assortment
Another nice set Morris #6-7 and using Dons suggestion #8 .i need to ask you if the BB really helps on such a distance as in #8?
Dec 02, 2014 at 08:24 AM
David Leask
p.1 #17 · p.1 #17 · Sandpiper Assortment
I love the sense of motion in these Morris, well done.
David
Dec 02, 2014 at 03:46 PM
p.1 #18 · p.1 #18 · Sandpiper Assortment
Thank you Michael,
I tried Don's suggestion and did not like the result. The balanced natural frame dose a lot for the composition.
As for the flash, the subject distance is only about 20 to 25 feet well withing the range of the SB910 even without the Better Beamer. With the better beamer I frequently see an effect at 50 to 100 feet and catchlight in the eyes for hundreds of feet.
Dec 02, 2014 at 06:32 PM
p.1 #19 · p.1 #19 · Sandpiper Assortment
David
Thank you David
