scalesusa Offline Upload & Sell: Off
The Kenko TC's (PRO 300 DGX) cause recent cameras to hang and require removal of the battery and TC to get it working again. It happens with only certain lenses, not all.
The issue is related to AFMA on the 5D MK III, and the 6D, and now the 7D MK II, it seems. Turn off AFMA and see if the issue goes away. The 100mmL is also impacted by the TC issue.
About all you can do is turn off AFMA, or use a Canon unit if you want AF to work properly. With the 100mm L, there is no nice work around.
