danski0224 Offline Upload & Sell: Off
AS Hanging also has a bottom rail and some cable fixtures that allow the cable to be placed under tension. String up some cables every foot or so, get some rare earth magnets, and voila. Won't work with frames, though.
A less expensive and traditional method would be picture moulding rail on the wall and then get the necessary hooks and line. Older homes with plaster walls had this moulding installed about 2" down from the ceiling- you can pick any aesthetically pleasing distance.
The moulding, hooks and line are available from many sources.
Lots of hook styles are available, and not as contemporary as the AS System rails, but you could use their line and line anchors to hold the frames from your hooks.
AS has steel cables with loops on one end.
AS has a kit that includes steel cable cutters and epoxy for the cut ends. You will need that or an equivalent if you have not worked with braided steel cable before.
