Mudge Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Cannot Read File message - Yellow Question mark- 6D issue | |
Thanks for the replies. Actually, I am not using a PC. Using a Macbook pro (about a year old). I haven't used a different cable yet. When I had the problem originally (about 3 months or so ago) I was running Mavericks and did update the EOS software (Canon tech had me do that).
I have used the different USB ports on the computer and it has happened when using both, I am pretty sure. Same problem has happened with two different cards. Each card has been reformatted.
Currently running Yosemite on the Mac, and EOS utility hasn't been updated to run with it. A fix I found was to simply select Mavericks as the operating system and "trick" the computer. But I don't think it is a software issue because I was having the problem before when I was running Yosemite.
I am not sure that it has happened when using the PC at work and downloading images.
Again, thanks.
