millsart Offline Upload & Sell: Off
snapsy wrote:
A more restricting limitation of current electronic shutters is banding under artificial lighting at certain shutter speeds. This should improve in future designs as sensor readout speeds are improved.
That is true, however, in actual use around the house, with a wide variety of incandescent, overhead florescent, and low wattage CFL bulbs, I've never really run into any issues.
Just like with any florescent bulb, you can have issues at certain shutter speeds if you seek them out, but they are also pretty easy to avoid.
Its not like an issue where you can't shoot anything with artificial light because of horrible banding. Global shutter would certainly be a welcome improvement, but I think a majority of A7s shooters aren't seeing issues in most shots with the current technology.
I don't know if the readout is any faster than the Panny GX7, but when specifically trying to induce rolling shutter effects, the A7s seems improved. Maybe a little faster line readout or something. Would stand to reason as it is a generation, if not two, newer than the GX7 sensor tech
