RustyBug Online Upload & Sell: On
Hmmm, not sure @ posting resize. I use FM frames frequently and have never noticed it resizing. Maybe, it is resizing due to file size. I keep my file sizes below 750 KB (adjust compression if needed) for posting on FM, even if physical dimensions are large.
It used to be that if your file was too large, FM wouldn't let you post @ error message. Fred may have changed things so that it simply resizes now (I'm guessing @ this).
Nice scene @ diggin, the stone house and the stones in the stream. Not diggin' the pano, likely due to the shape of the house being a bit more squarish with a vertical component to it ... seems it could benefit from additional negative space above.
The house looks like it is suffering from the effects of distortion (mustache known @ The King). Power lines are pretty subjective @ keep vs. remove. I'd like to see them cloned out, in this one. Kinda depends on if this is a "general" scene or a "known" one. Since I don't know the scene, I wouldn't miss them as supposed to be there.
