wellsjt Offline Upload & Sell: Off
okafoja wrote:
Shutter speed was kind low for D810. 1/60
I suspected that which is why I asked.
This test image has a lot of variables set against it in terms of IQ: simply too low a shutter speed (for the combination of subject, focal length, and the fact it is handheld), low ambient lighting conditions, high ISO, and likely a wide open aperture.
That said, it's actually not too bad! You're too hard on yourself. With the tough conditions listed above, you probably shouldn't be pixel peeping this one, but I think if you were to post process this normally (fixing white balance, applying effective noise reduction to combat the high ISO noise, etc.) and printed it at a normal size, I think it would be acceptably sharp. I don't think someone would look at the print and say it's out of focus.
Before giving up on the lens or adjusting the fine-tune, you need a repeat under more controlled and better conditions.
