Alex Nail Offline Upload & Sell: Off
The comparison is on the Amazon.com review. It's anecdotal but the reviewer does state that whist the Gitzo tripod is slightly better the Induro model is far better value. Sadly there is no actual information on stability, just people's opinions.
The CT-314 is 2.2kg, 350g heavier than my current tripod and 800g heavier than the 2542L.
I am trying to save weight for long distance backpacking (2 weeks without resupply) but my previous experience with 'traveller' type models is that they are both too short (I am 6'4") and lack stability in the kind of wind you can get in the mountains(the GT1541 didnt have a wide enough base in my opinon). My current tripod generally takes these conditions in its stride, albeit with some sheilding/weighing down required occasionally.
What I am looking for is a hiking tripod which is as stable as my 2541EX with a similar or greater working height whilst saving a worthwhile amount of weight (ideally 400g or so). I'm not really concerned about price as long as its under about £600 ($1000). The height is particularly important, not just because I am tall, but also because I regularly set up on steep ground (mountains sides) and having long tripod legs helps a lot there.
Requirements would probably be as follows:
Weight: 1.3-1.5kg
Minimum '2 series' size legs > 29mm diameter
>150cm without centre column
170cm approx with centre column
The weight is flexible. For example I might accept a heavier tripod (1.8kg) if I knew it was significantly more stable. That said, weight is very significant to me because my camera kit is a heavy component of my backpacking setup, so everything that has a weight has to be justifyable, hence the question about the heavier new GT2543L which seems a lot like 300g for a negligeable stability increase?
