AGeoJO Offline Upload & Sell: On
I hear you, Dennis. But, and it is a BIG but, keep in mind that if Fuji comes up with a FF body, the body won't be that small and way more importantly, all those nice APS-C lenses will be generating only images at APS-C crop although your camera is FF. Ouch . Then they have to design a new set of FF lenses again to accommodate the FF body. If they keep the same mount... What if they have to make the mount wider to accommodate the FF sensor? If it is coming down to it, it will take a few years to sort things out and I am sure Sony will reinforce the FE lens lineup by then.
Currently, there are 4 Sony FF FE lenses; two zooms and two primes. Only one so far, the 24-70mm f/4 didn't quite get great reviews, at least not at the ends of both FL in the zoom range. The images generated by that lens I have seen so far are actually great but leave that one out. The other 3 are truly great performers.
You will have to make the call which way you want to take. Something to ponder, huh?
