LightShow Offline Upload & Sell: Off
johnahill wrote:
Yes, I've used eclipse with pec-pads but most of the time now use a lenspen or micro-fibre cloth.
I'm not a big fan of a lens pen unless you use a new pen every time you clean, the risk of scratching your lens goes up every time you use that same pen, I use a new pec pad for every lens, and more if it's really dirty, especially new lenses that have a layer of dust on them.
Oils from your finger will be sucked into the Eclipse solution, and leave a residue, so it's critical your hands are clean, nitrile gloves or nitrile finger protecters will also do the job.
ROR (Risudual Oil Remover) is good at removing oil from a lens(don't use it on a sensor) which is followed with Eclipse.
