CanadaMark Offline Upload & Sell: Off
Immediately go to custom setting A3 (Focus Tracking With Lock On), and turn focus delay OFF. Cannot emphasize that enough. Nikon defaults this to "ON" from the factory, and I can only imagine how many Nikon vs Canon AF tests (and whatever else) have been unknowingly completely irrelevant due to this oversight. It drastically affects the speed the camera will change focus for subjects moving toward/away the camera, and is useful in far less situations than if it had just defaulted OFF.
Other than that, I find both systems to be intuitive enough not to worry about much else, it won't take long for you at all to get used to it. There is a lot of personal preference involved as well, such as using the AF-ON button, Fn buttons, etc. which you will need to decide on yourself.
Command dials work the other way, but you can change that in custom settings as well to whatever you prefer. Zoom works the other way on lenses as well, small adjustment.
Oh, I'd probably turn high ISO NR off as well - software always does a better job anyhow.
Congrats on the switch, the D7100/D810 are the pair to beat at the moment, you should be very pleased.
