Macro World Resource
Archive 2014 · Canon lens recommendation?
Ccugolf
p.1 #1 · p.1 #1 · Canon lens recommendation?
What non L lens would you recommend for macro?
Putting it on a 60d body.
Jul 05, 2014 at 01:18 AM
skibum5
p.1 #2 · p.1 #2 · Canon lens recommendation?
60mm EF-S unless you need the bit of extra working distance of the 100 EF
Jul 05, 2014 at 04:25 AM
Dalantech
p.1 #3 · p.1 #3 · Canon lens recommendation?
I cannot agree more! The EF-S 60mm is actually a 37mm lens at 1x, so it only takes 37mm of extension to get to 2x...
Jul 06, 2014 at 03:09 PM
coder
p.1 #4 · p.1 #4 · Canon lens recommendation?
Canon 100 (non is). 60 is really good from what I have seen.
Also, would you go for non canon? There are many good macro lenses. Tamron 90 ( I had one) is great.
Sigma 150 is great ( I've had one for years).
Jul 08, 2014 at 09:41 PM
p.1 #5 · p.1 #5 · Canon lens recommendation?
The 60mm EF-S is an excellant macro lens! I bought mine 8+ years ago when I went digital to a 20D.
It is tack sharp! Best "bang" for the buck also!
I have kept it and a crop body Canon just so I can use it!
I always recommend the 180mm Macro. It is my most used lens.
Good luck!
Jul 13, 2014 at 01:07 PM
dtolios
p.1 #6 · p.1 #6 · Canon lens recommendation?
Question for those that might have tried it: If you were to used it with an extension tube on a FF body, how's the frame coverage?
I would guess the tube helps the mirror "clear" the EF-S portion of the equation, but how are the corners? Is the image projected from far enough to cover FF?
Jul 14, 2014 at 06:51 PM
GCasey
p.1 #7 · p.1 #7 · Canon lens recommendation?
I use the 50, f/2.5 Macro and love it.
Jul 14, 2014 at 07:04 PM
JohnBrose
p.1 #8 · p.1 #8 · Canon lens recommendation?
what price range? what focal length are you thinking? I would suggest the canon 100 f2.8 usm macro or if you have more $ then the 100mm L macro.
Jul 14, 2014 at 07:47 PM
CW100
p.1 #9 · p.1 #9 · Canon lens recommendation?
also look at the Tamron 90mm 2.8 macro (all three versions are sharp and cheaper than the Canon 1:1 macro lens)
Jul 19, 2014 at 05:56 PM
Hungle
p.1 #10 · p.1 #10 · Canon lens recommendation?
I have heard that Canon 100 2.8 is a very good macro lens but haven't tried that. I will try it one day
Jul 27, 2014 at 04:45 PM
Ccugolf
p.1 #11 · p.1 #11 · Canon lens recommendation?
Thanks all for the advice. I went with the 60mm EFS.
Aug 16, 2014 at 02:08 AM
Dalantech
p.1 #12 · p.1 #12 · Canon lens recommendation?
Sorry that I'm just now responding to your question -had to reload my PC. Here's a shot with the EF-S 60mm with a 12mm tube taken with a 1.3x crop camera (Canon 1D MKIII):
There won't be any coverage issues with using it on a full frame camera -the lens actually projects a large image circle on the 1.6x crop bodies.
Aug 16, 2014 at 07:21 PM
CW100
p.1 #13 · p.1 #13 · Canon lens recommendation?
OK, but I agree with the others, the Canon 100mm 2.8 non-L is cheap (used $350) and pretty good
60D
natural light, no tubes
http://farm6.staticflickr.com/5583/14847782776_6ab4b53403_b.jpg
Aug 19, 2014 at 02:40 PM
