John Webb Offline Upload & Sell: Off
John Thanks.
Both LR and CS6 are on the same version of ACR 8.4, and I believe that is where my problem started. Currently LR5 indicates LR5.4 and ACR 8.4, CS6 indicated ACR 8.4.0.199.
Prior to that, when I 1st upgraded to LR5 from LR4.4 (two weeks ago), LR was 5.4 and CS6 was on 8.3. I did get the warnings that there was not a match and would indicate that I wanted to render in lightroom. I updated ACR to 8.4 so that the two would match, the warning box on the general tab is now greyed out, so unable to reset the warning dialogue.
Is there an alternate way of requesting to render in LR? Could this be a compatibility issue with ACR8.4 and OSX 10.9 Mavericks, On on a iMac.
Even when I open a raw image directly from CS6 - and ACR raw editor comes up I get the same results. Once finished with the raw editor the file opens in CS6 as a net or dng, dependent on the file processed in ACR. not all the adjustments seemed to have come across and again unable to use the liquify tool.
This is why I'm thinking there might me a incompatibility with ACR 8.4 and Mavericks OS.
