Archive 2014 · AF Fine Tune
p.1 #1 · p.1 #1 · AF Fine Tune
A question, once an adjustment has been made and recorded in-camera, does the adjustment automatically go into effect when the lens is installed or is it necessary to turn on auto fine tune?
May 17, 2014 at 05:05 PM
RoyC
p.1 #2 · p.1 #2 · AF Fine Tune
AF Fine stays on until you turn it off through the menu system. If on, it automatically adjust AF per saved adjustment. Where the default or specific by lens.
May 17, 2014 at 05:09 PM
p.1 #3 · p.1 #3 · AF Fine Tune
So, if I understand this... as long as the af fine tune is on via the menu, the camera will make appropriate adjustments for each calibrated lens/lens combination that is placed on the camera.
May 17, 2014 at 06:58 PM
Gregstx
p.1 #4 · p.1 #4 · AF Fine Tune
Yes
May 17, 2014 at 08:05 PM
lorac
p.1 #5 · p.1 #5 · AF Fine Tune
potinam wrote:
Anybody have any instruction to check focus or fine tune the lens. I want to check my lens. Thanks.
Check out this link, best method I've encountered. This is for Canon cameras with the most complete description. The link for Nikon cameras is in the first post of the thread. There's also a video link as well.
http://www.fredmiranda.com/forum/topic/1187247
May 18, 2014 at 01:28 AM
Mnd1
p.1 #6 · p.1 #6 · AF Fine Tune
There are exceptions to this. In the case of Zeiss lenses for example only ONE lens is recognized.
May 18, 2014 at 01:44 AM
lorac
p.1 #7 · p.1 #7 · AF Fine Tune
I don't understand using AF Fine tune for a manual focus lens?
Nikon cameras will only recognize one Tokina lens, so if you have more than one you have to choose which needs AF Fine Tune more.
May 18, 2014 at 05:54 AM
