Archive 2014 · Messin' with the Sony RX100 ver II
Larry Williams
p.1 #1 · p.1 #1 · Messin' with the Sony RX100 ver II
Greetings all,
Hauling around a Canon MRK IV with a 500mm lens attached to a heavy tripod gets tiring. While doing so, often times an opportunity arises for a wide angle shot. With that, I took note from a friend of mine, Burt. He carries a Canon G12 with him. It seems that he is using the G12 more and more while leaving his Nikon DSLR's at home.
Looking into the many options available, I settled on Sony's RX-100 version II because it is very small and had great reviews.
Wanting to see what this little gem would do, I was messing around with it in very bright sunlight. Setting it to Automatic I fired away. Here are two results.
Larry
  DSC-RX100M2    28-100mm F1.8-4.9 lens    10mm    f/5.0    1/800s    160 ISO    0.0 EV
  DSC-RX100M2    28-100mm F1.8-4.9 lens    10mm    f/5.6    1/320s    160 ISO    0.0 EV
May 11, 2014 at 02:43 AM
p.1 #2 · p.1 #2 · Messin' with the Sony RX100 ver II
Both are nice Larry, the first my pick
May 11, 2014 at 02:44 AM
surfnron
p.1 #3 · p.1 #3 · Messin' with the Sony RX100 ver II
Both look good Larry ~ Ron
May 11, 2014 at 09:01 PM
jusjee
p.1 #4 · p.1 #4 · Messin' with the Sony RX100 ver II
Both very nice. I have to know why you chose the mk2 over mk1 though.
May 13, 2014 at 02:19 PM
Russ Welke
p.1 #5 · p.1 #5 · Messin' with the Sony RX100 ver II
Like them both Larry.
Russ
May 14, 2014 at 05:00 AM
