gurtch Offline Upload & Sell: Off
Hi all. I only have two native lenses: the 35 mm and 55mm. For my landscape/ seascape work, I usually shoot aperature preferred, typically f11 to f13. I have used SLRs ( film and digital) for many years, and am used to focusing wide open, either manually, or AF. This gives me a bright view, even in bright daylight, and limited depth of field because of the wide open aperature. I have tried to use my A7r that way, but I must be screwing up, because I cannot do it. If I select Aperature Preferred, set the f stop to, say, f13 the lens (both of them) stop down to shooting aperature, darkening the view somewhat, and making manual focus tweaking impossible, because of the f13 depth of field. I like the DMF idea, that you merely keep your finger on the shutter release after AF, then move the focus ring, and the image magnifies, and you manually tweak focus; but with the lens stopped down, this idea fails for me. Am I screwing up? I am about ready to go back to my DSLRS, which I fortunately kept.
