Justin Grimm Offline Upload & Sell: Off
I have done a few shots with a mix of exposures like what you are describing, even while using a TS lens. At least for the composition you have shown, I doubt any tilt is needed to get everything in focus. You could shoot the foreground and city with your desired f-stop and probably get sharper results then tilting that much to where the lens performs less then perfect. Manually adjusting your camera settings won't be a problem either. Even if the composition does change a little bit, you will only be blending in the sky, so nothing really needs to line up perfectly. I have done these shots with flowers 4" from the lens and still didn't have any problems with alignment.
Personally I think shooting twilight scenes like these is very easy and fun while out there, however making the blend look natural and clean is the biggest hurdle. Good luck!
