cambyses Offline Upload & Sell: On
ronno wrote:
Yeah I am going to try it out, but thought if it is subtle I will be sitting there doing lens calibration, etc...it could be a while.
There will be no need for any lens calibration: (a) if it has the issue, the problem will be somewhat obvious when you compare the focus quality of your center point with your left points and (b) Lens calibration (i.e., micro AF adjustment) would not even be applicable here. That is because you will want to compare the focus quality of your left focus points with your center points. But micro AF adjustment is done using a given focus point (typically the center one, but technically could be any of the focus points). And so, lets say if you use one of your left AF points to come up with a micro adjustment value, and if your camera has the left AF issue, then your micro adjustment will actually screw up your focus when using your center point.
