Cableaddict Offline Upload & Sell: Off
Here's info I recently got from AB:
"The Cyber Commander CAN be used with a combination of speedlights and the Einstein units. When using the regular CyberSync battery powered receiver (part CSRB for $69.95) you can simply fire the speedlight as long as it is set to the same frequency as the Cyber Commander. If you use the CyberSync plus model battery powered receiver (part CSRB+ for $89.85), you can wirelessly trigger, group and individually meter the speedlight .
- However, the option to adjust the flash output setting is not available. This function is only available when using the Cyber Commander with our lights. "
